Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under test is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 2.5 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 1,920 x 1,080. We also check that 4x AA and 4x AF are enabled and that tessellation is set to Standard. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
AMD Radeon HD 5770 1GB
AMD Radeon HD 6870 1GB
AMD Radeon HD 6950 1GB
Nvidia GeForce GTX 460 768MB
Nvidia GeForce GTS 450 1GB
AMD Radeon HD 5850 1GB
Nvidia GeForce GTX 460 1GB (custom cooler)
MSI Radeon HD 6850 Cyclone 1GB
Nvidia GeForce GTX 550 Ti 1GB (custom cooler)
AMD Radeon HD 5870 1GB
AMD Radeon HD 6850 1GB
Nvidia GeForce GTX 560 Ti 1GB (custom cooler)
AMD Radeon HD 4870 1GB (custom cooler)
Nvidia GeForce GTX 570 1.3GB
AMD Radeon HD 6950 2GB
Nvidia GeForce GTX 480 1.5GB (custom cooler)
Nvidia GeForce GTX 470 1.3GB
Nvidia GeForce GTX 580 1.5GB
Nvidia GeForce GTX 260 (rev 2) 896MB
AMD Radeon HD 6990 4GB (stock)
Nvidia GeForce GTX 590 3GB
AMD Radeon HD 6970 2GB
AMD Radeon HD 5970 2GB
AMD Radeon HD 6990 4GB (overclocked)
128
134
134
137
137
137
139
139
139
139
143
143
143
144
145
148
151
152
155
156
156
157
167
179
System Power consumption in Watts
Nvidia GeForce GTX 260-216 896MB
202
221
226
228
237
239
241
242
243
254
256
270
272
272
298
302
322
324
339
357
417
463
491
*Note*
The HD 5990 2GB was unable to complete a run of the Unigine Heaven benchmark, and as such is ranked with a zero for load.
Thermal Performance
24
21
21
21
21
20
18
18
18
18
17
16
15
15
15
14
14
13
13
13
11
11
10
Delta T in °C
63
62
60
59
59
59
58
55
54
53
51
51
48
47
46
43
41
38
36
35
34
30
Delta T in °C
*Note*
Read our Performance Analysis
